19-02-2021, 05:11 PM
Most likely that the face of the fuel pump where it bolts to the crankcase is not flat. This often happens when the bolts have been overtightened. You can repair it by firstly removing the actuating lever and then rubbing the flange on some fine emery cloth on a flat surface. Then re-assemble using gasket compound on both sides of the gasket.
