17-02-2021, 10:43 PM
Spot on Tony, just did this myself a few days ago. Knocking the springs sideways definitely helps.I also put a 1/2” bar in the spring hole in the top of the chassis member, you can then knock it backwards and forwards an 1/8” of an inch, every little helps!. The one I just did has at some time been sandblasted with the springs in position so sand trapped between spring and chassis on all 4 sides.
The chassis in the picture looks pretty crusty.
