Holes in sump
Hi Howard, if you are determined to repair this get some solder paint, it is a mixture of solder and flux, you brush it on completely covering the area to be trained then heat with blow lamp or similar the solder will still to the surface and the flux will wash off after.
Needs to be spotlessly clean, strip and clean pad in the drill for that.
BW Gene
See what my iPad did? Should read treated
Holes in sump - by Howard Wright - 16-02-2021, 05:31 PM
RE: Holes in sump - by dickie65 - 16-02-2021, 06:13 PM
RE: Holes in sump - by Robert Leigh - 16-02-2021, 07:21 PM
RE: Holes in sump - by Zetomagneto - 16-02-2021, 07:55 PM
RE: Holes in sump - by AustinWood - 16-02-2021, 09:12 PM
RE: Holes in sump - by Hedd_Jones - 16-02-2021, 09:33 PM
RE: Holes in sump - by Howard Wright - 17-02-2021, 08:56 AM
RE: Holes in sump - by Jacob Fowkes - 17-02-2021, 09:30 AM
RE: Holes in sump - by Zetomagneto - 17-02-2021, 10:45 AM
RE: Holes in sump - by Dave Mann - 19-02-2021, 09:25 PM
RE: Holes in sump - by Austin in the Shed - 19-02-2021, 09:33 PM
RE: Holes in sump - by Howard Wright - 20-02-2021, 08:52 AM
RE: Holes in sump - by Dave Mann - 20-02-2021, 10:22 AM
RE: Holes in sump - by John Mason - 20-02-2021, 10:34 AM
RE: Holes in sump - by Duncan Grimmond - 20-02-2021, 11:10 AM
RE: Holes in sump - by Peter Clayton - 20-02-2021, 11:25 AM
RE: Holes in sump - by andrew34ruby - 20-02-2021, 04:05 PM
RE: Holes in sump - by Duncan Grimmond - 20-02-2021, 06:41 PM
