Over tightened end caps
#33
HI Simon,
you will need to have the stretch length for your application
and only works if you can access both ends of the bolt when installed  (ie) Bolt And Nut
you also need to measure length of bolt before you start as stretch is usually on average  5 to 8 th
the length before you start is critical because if on a subsequent Build the length has permanently increased by .001 the bolt is scrap
Colin
NZ
Over tightened end caps - by 12jslater - 30-10-2020, 07:58 PM
RE: Over tightened end caps - by Nick Turley - 30-10-2020, 08:16 PM
RE: Over tightened end caps - by Steve Jones - 30-10-2020, 09:09 PM
RE: Over tightened end caps - by 12jslater - 30-10-2020, 09:14 PM
RE: Over tightened end caps - by Bob Culver - 30-10-2020, 09:16 PM
RE: Over tightened end caps - by Zetomagneto - 30-10-2020, 09:54 PM
RE: Over tightened end caps - by Chris KC - 30-10-2020, 11:01 PM
RE: Over tightened end caps - by Dave Wortley - 31-10-2020, 09:43 AM
RE: Over tightened end caps - by Zetomagneto - 31-10-2020, 09:47 AM
RE: Over tightened end caps - by John Mason - 31-10-2020, 10:13 AM
RE: Over tightened end caps - by Reckless Rat - 31-10-2020, 10:13 AM
RE: Over tightened end caps - by Charles P - 31-10-2020, 10:24 AM
RE: Over tightened end caps - by Dave Mann - 31-10-2020, 10:47 AM
RE: Over tightened end caps - by Bob Culver - 31-10-2020, 11:05 AM
RE: Over tightened end caps - by Alan - 31-10-2020, 11:14 AM
RE: Over tightened end caps - by andrew34ruby - 31-10-2020, 02:42 PM
RE: Over tightened end caps - by Colin Wilks - 31-10-2020, 03:20 PM
RE: Over tightened end caps - by Ray White - 31-10-2020, 03:43 PM
RE: Over tightened end caps - by Chris KC - 31-10-2020, 07:07 PM
RE: Over tightened end caps - by Dave Mann - 31-10-2020, 09:58 PM
RE: Over tightened end caps - by John Mason - 31-10-2020, 10:16 PM
RE: Over tightened end caps - by Zetomagneto - 31-10-2020, 10:36 PM
RE: Over tightened end caps - by Alan - 31-10-2020, 11:47 PM
RE: Over tightened end caps - by Bob Culver - 01-11-2020, 07:18 AM
RE: Over tightened end caps - by John Mason - 01-11-2020, 10:37 AM
RE: Over tightened end caps - by Ray White - 01-11-2020, 11:02 AM
RE: Over tightened end caps - by Zetomagneto - 01-11-2020, 02:02 PM
RE: Over tightened end caps - by Dave Mann - 01-11-2020, 09:10 PM
RE: Over tightened end caps - by JonE - 12-02-2021, 01:32 PM
RE: Over tightened end caps - by Robert Leigh - 12-02-2021, 01:56 PM
RE: Over tightened end caps - by jansens - 12-02-2021, 08:50 PM
RE: Over tightened end caps - by Dave Mann - 12-02-2021, 09:02 PM
RE: Over tightened end caps - by Colin Reed - 12-02-2021, 09:35 PM
RE: Over tightened end caps - by jansens - 14-02-2021, 07:55 AM
RE: Over tightened end caps - by Dave Wortley - 14-02-2021, 10:22 AM
RE: Over tightened end caps - by Dave Mann - 14-02-2021, 10:45 AM
