12-02-2021, 05:43 PM
Good Oil Pressure !!! hopefully no more than 6 Psi cold, if its more check the oil jets under the little brass nuts beside the block. Make sure the engine is a TDC before poking wire into the jets so that any gunge falls into the oil gauze not the crankshaft oil pockets.
Is there a plate at the bottom of the steering column that will enable the whole lot to be brought into the car and out once the drag link is undone ???
