Welding with a wood frame
It’s a Mk1 ruby from 1934.
I would rather not remove good wood if I can help it but I don’t want a fire either!
Sorry should have said I need to weld just above the bottom door hinges on both sides so I can fit a repair panel to the bottom of the panel immediately in front if the door, as well as the sill below that.
Welding with a wood frame - by darcher121 - 10-02-2021, 12:33 PM
RE: Welding with a wood frame - by Martin Prior - 10-02-2021, 02:24 PM
RE: Welding with a wood frame - by darcher121 - 10-02-2021, 02:35 PM
RE: Welding with a wood frame - by Martin Prior - 10-02-2021, 04:06 PM
RE: Welding with a wood frame - by darcher121 - 10-02-2021, 05:31 PM
RE: Welding with a wood frame - by Tony Press - 10-02-2021, 10:57 PM
