Front bearings
(09-02-2021, 11:46 AM)Parazine Wrote:
(08-02-2021, 04:05 PM)dannyteal1990 Wrote: I've also heard that old bearings can give years worth of service but since they are a bit of a pain to get in and out I thought it proved well to change them for new while I had the engine in pieces.
They can but it's worth taking them apart to check for rust pitting first. To do this, I put the bearing in the palm of my hand and tap the thrust side smartly with a copper hammer to force it apart. You can then inspect the tracks with a loupe to check for rust pits, also the balls, which can be renewed for little cost. When you are satisfied, the bearing can be tapped back together again.
Any rust pits, discard the bearing. I ran one years ago with a few small pits, after 5000 miles, the bearing tracks were completely gone.
Unfortunately knocking angular contact bearings apart can indent the balls causing later problems.
Using unmatched balls defeats the purpose of the original set of carefully matched balls.
(09-02-2021, 09:44 PM)dickie65 Wrote: I make sure that I buy ground matched bearings its more money but they are available.
I would have thought that a matched pair of Austin 7 SKF AMS 9 or RHP MJT 1 1/8  angular contact bearings (imperial size) would be very difficult to find.
Especially the later narrow outer ring pair.
Where do you get these ?
Front bearings - by dannyteal1990 - 06-02-2021, 12:19 PM
RE: Front bearings - by John Cornforth - 06-02-2021, 02:36 PM
RE: Front bearings - by bystander - 06-02-2021, 02:47 PM
RE: Front bearings - by Parazine - 06-02-2021, 02:47 PM
RE: Front bearings - by Robert Leigh - 06-02-2021, 03:28 PM
RE: Front bearings - by Tony Betts - 06-02-2021, 05:05 PM
RE: Front bearings - by dannyteal1990 - 06-02-2021, 06:31 PM
RE: Front bearings - by Zetomagneto - 06-02-2021, 07:22 PM
RE: Front bearings - by Bob Culver - 06-02-2021, 08:26 PM
RE: Front bearings - by Robert Leigh - 06-02-2021, 08:27 PM
RE: Front bearings - by Tony Press - 06-02-2021, 10:53 PM
RE: Front bearings - by bystander - 07-02-2021, 10:31 AM
RE: Front bearings - by Bob Culver - 08-02-2021, 12:10 AM
RE: Front bearings - by dannyteal1990 - 08-02-2021, 04:05 PM
RE: Front bearings - by Parazine - 09-02-2021, 11:46 AM
RE: Front bearings - by dickie65 - 09-02-2021, 09:44 PM
RE: Front bearings - by Tony Press - 09-02-2021, 10:37 PM
RE: Front bearings - by Bob Culver - 10-02-2021, 12:13 AM
RE: Front bearings - by Tony Press - 10-02-2021, 12:53 AM
RE: Front bearings - by RossV - 10-02-2021, 12:57 AM
RE: Front bearings - by bystander - 10-02-2021, 09:23 AM
RE: Front bearings - by Parazine - 10-02-2021, 12:59 PM
RE: Front bearings - by dickie65 - 10-02-2021, 09:04 PM
