SU conversion
#21
My 31 SWB saloon has run for 18 years with a side-draught SU on a standard cast iron manifold (with the inlet restriction bored out) and I use the standard scuttle tank with no pump.  I have never had any problems with fuel starvation but always carry a spare gallon just in case!  I have never used an in-line filter. It is a  simple job to remove the fuel tank and get all the muck out.  I check the fine gauze filter in the banjo union on the carb about once a month.  The AN or EB needles seem pretty good.
I have recently fitted one of the Ricardo aluminium cylinder heads and the results are very encouraging.
SU conversion - by Robin Gooders - 04-11-2017, 10:31 PM
RE: SU conversion - by Peter Naulls - 04-11-2017, 11:10 PM
RE: SU conversion - by Robin Gooders - 05-11-2017, 12:05 AM
RE: SU conversion - by Derek Sheldon - 05-11-2017, 12:24 AM
RE: SU conversion - by Bob Culver - 05-11-2017, 01:48 AM
RE: SU conversion - by Jeff Taylor - 05-11-2017, 12:23 PM
RE: SU conversion - by Chris KC - 05-11-2017, 09:02 AM
RE: SU conversion - by Alan - 05-11-2017, 10:51 AM
RE: SU conversion - by Bob Culver - 05-11-2017, 07:07 PM
RE: SU conversion - by Austin in the Shed - 05-11-2017, 09:07 PM
RE: SU conversion - by Peter Naulls - 05-11-2017, 11:59 PM
RE: SU conversion - by Paul N-M - 20-01-2018, 02:41 PM
RE: SU conversion - by Robin Gooders - 06-11-2017, 12:27 AM
RE: SU conversion - by Bob Culver - 09-11-2017, 08:10 PM
RE: SU conversion - by Robin Gooders - 19-01-2018, 07:06 PM
RE: SU conversion - by Ian Williams - 19-01-2018, 09:01 PM
RE: SU conversion - by Colin Swinbourne - 19-01-2018, 09:40 PM
RE: SU conversion - by Robin Gooders - 20-01-2018, 10:21 AM
RE: SU conversion - by GK5268 - 19-01-2018, 11:58 PM
RE: SU conversion - by Colin Swinbourne - 20-01-2018, 10:47 AM
RE: SU conversion - by Terry McGrath - 20-01-2018, 01:13 PM
RE: SU conversion - by Malcolm Parker - 20-01-2018, 02:31 PM
RE: SU conversion - by Colin Wilks - 21-01-2018, 11:27 AM
