26-01-2021, 04:04 AM
Rich jets often eliminate flat spot and similar problems. Over a wide rich range power is little altered, but economy is. There is always the possibility someone has enlargened the venturi calling for larger jets. If done so as to preserve the venturi form may not be immediately obvious. Also encounter drilled and reamed jets. Can use the taper of a safety pin as a gauge.
