Starts, then dies
Nick. Have a look at the carb under the throttle butterfly is a small jet that allows air to pass through the carb when the butterfly is shut thus allowing air to enable combustion. To get to the jet you need to remove the small brass screw underneath the carb. Extremel care must be taken when removing this jet to prevent damage. Sometimes it is better to clean the jet without removing it
John Mason.
Starts, then dies - by Nick Salmon - 19-01-2018, 01:59 PM
RE: Starts, then dies - by Martin Prior - 19-01-2018, 02:38 PM
RE: Starts, then dies - by Nick Salmon - 19-01-2018, 03:46 PM
RE: Starts, then dies - by John Mason - 19-01-2018, 03:55 PM
RE: Starts, then dies - by Nick Lettington - 19-01-2018, 04:38 PM
RE: starts then stops - by Thowdfella - 19-01-2018, 04:50 PM
RE: Starts, then dies - by Nick Salmon - 19-01-2018, 06:03 PM
RE: Starts, then dies - by JonE - 19-01-2018, 07:25 PM
RE: Starts, then dies - by Nick Salmon - 19-01-2018, 07:58 PM
RE: Starts, then dies - by Reckless Rat - 19-01-2018, 08:16 PM
