15-01-2021, 09:49 AM
I think you can view it as a rite of passage Peter! And yes I'd wholeheartedly agree - do it thoroughly once and there should be no need to go inside the box again.
For what it's worth here's the gadget I use for the balls & springs - it's stiff enough that you can simply rotate & pop each one in in turn without the others popping out. Then squeeze up with mole grips and a sharp whop with a hide hammer (or equivalent...) will snap the sleeve into place.
