30-12-2020, 05:55 PM
Ruairidh, when I did mine I searched all over trying to find some but failed. Thinking out of the box I got a bicycle inner tube cut each side of the valve to make a long tube then split it length ways. I cut sections for the three sides. I did the straight pieces first putting the rubber around the glass before putting it into the frame. Then did the curved side/top. When all screwed up I trimmed off the excess rubber with a Stanley knife. You can put black coloured sealant between glass and rubber if it’s not a tight fit in the frame.
John Mason.
John Mason.
