Compression pressures
Hi Folks,
The results are in.
Engine was run to warm it but not hot enough to burn fingers on plug tops.
All tests were done running a 6v starter on 12 volts as the car has been 12 volts for many years.
Hand throttle wide open.
No 1 = 130 psi 9 Bar
No 2 = 130 psi 9 Bar
No 3 = 130 psi 9 Bar
No 4 = 100 psi 7 Bar I put oil into this cylinder and tried again with the same result.
So I have a poorly sealing valve on number 4
I will not do anything about this yet as the engine still pulls well although I will check the valve clearances.
Compression pressures - by Barry Townsend - 30-11-2019, 09:13 PM
RE: Compression pressures - by Tony Press - 30-11-2019, 11:59 PM
RE: Compression pressures - by Chris KC - 01-12-2019, 04:06 AM
RE: Compression pressures - by Barry Townsend - 01-12-2019, 11:21 AM
RE: Compression pressures - by David Stepney - 01-12-2019, 01:38 PM
RE: Compression pressures - by Chris KC - 01-12-2019, 02:01 PM
RE: Compression pressures - by Bob Culver - 01-12-2019, 08:42 PM
RE: Compression pressures - by Stuart Giles - 01-12-2019, 09:24 PM
RE: Compression pressures - by dickie65 - 29-12-2020, 10:07 PM
RE: Compression pressures - by Zetomagneto - 29-12-2020, 11:36 PM
RE: Compression pressures - by dickie65 - 30-12-2020, 12:07 AM
RE: Compression pressures - by dickie65 - 30-12-2020, 03:45 PM
