Compression pressures
Hi Zeto,
I have always done compression tests with the engine running when possible.
It gives me a more accurate balance across the engine.
Being a pressure fed 65 its nigh on impossible to crank the thing by hand ! as soon as the oil pressure rises it pushes the handle out of engagement.
I do not want to overheat the starter motor with too much cranking either.
I will charge the battery up and take all the plugs out and give it a go on the starter motor tommorow though.
Compression pressures - by Barry Townsend - 30-11-2019, 09:13 PM
RE: Compression pressures - by Tony Press - 30-11-2019, 11:59 PM
RE: Compression pressures - by Chris KC - 01-12-2019, 04:06 AM
RE: Compression pressures - by Barry Townsend - 01-12-2019, 11:21 AM
RE: Compression pressures - by David Stepney - 01-12-2019, 01:38 PM
RE: Compression pressures - by Chris KC - 01-12-2019, 02:01 PM
RE: Compression pressures - by Bob Culver - 01-12-2019, 08:42 PM
RE: Compression pressures - by Stuart Giles - 01-12-2019, 09:24 PM
RE: Compression pressures - by dickie65 - 29-12-2020, 10:07 PM
RE: Compression pressures - by Zetomagneto - 29-12-2020, 11:36 PM
RE: Compression pressures - by dickie65 - 30-12-2020, 12:07 AM
RE: Compression pressures - by dickie65 - 30-12-2020, 03:45 PM
