Compression pressures
Just a note on my tuned engine.
I have done a test on number one cylinder with the engine warm and running at 1000 rpm
I am getting a reading of 125 psi
This is with a ported block race spec camshaft big valves and a Ricardo Head.
1 1/2" pressure fed crankshaft so not worried about causing a tempory miss fire.
The engine had a freshen up with new pistons about two years ago.
Compression pressures - by Barry Townsend - 30-11-2019, 09:13 PM
RE: Compression pressures - by Tony Press - 30-11-2019, 11:59 PM
RE: Compression pressures - by Chris KC - 01-12-2019, 04:06 AM
RE: Compression pressures - by Barry Townsend - 01-12-2019, 11:21 AM
RE: Compression pressures - by David Stepney - 01-12-2019, 01:38 PM
RE: Compression pressures - by Chris KC - 01-12-2019, 02:01 PM
RE: Compression pressures - by Bob Culver - 01-12-2019, 08:42 PM
RE: Compression pressures - by Stuart Giles - 01-12-2019, 09:24 PM
RE: Compression pressures - by dickie65 - 29-12-2020, 10:07 PM
RE: Compression pressures - by Zetomagneto - 29-12-2020, 11:36 PM
RE: Compression pressures - by dickie65 - 30-12-2020, 12:07 AM
RE: Compression pressures - by dickie65 - 30-12-2020, 03:45 PM
