12 Volt fuel tank sender unit
I think you should be able to remove the gauge by undoing the knurled screw and washer that holds the clamp to the back of the dashboard, but disconnect the battery first in case you short a wire .
RE: 12 Volt fuel tank sender unit - by Michael - 14-01-2018, 07:43 PM
RE: 12 Volt fuel tank sender unit - by Michael - 15-01-2018, 10:28 AM
RE: 12 Volt fuel tank sender unit - by Reckless Rat - 16-01-2018, 05:21 PM
RE: 12 Volt fuel tank sender unit - by Roger - 18-01-2018, 06:52 PM
RE: 12 Volt fuel tank sender unit - by Roger - 19-01-2018, 10:12 AM
RE: 12 Volt fuel tank sender unit - by Tony Press - 19-01-2018, 01:52 AM
RE: 12 Volt fuel tank sender unit - by David.H - 19-01-2018, 12:02 PM
RE: 12 Volt fuel tank sender unit - by Tony Press - 19-01-2018, 10:15 PM
RE: 12 Volt fuel tank sender unit - by David.H - 19-01-2018, 11:45 PM
RE: 12 Volt fuel tank sender unit - by GK5268 - 19-01-2018, 11:49 PM
