Cam bearing oil restriction
I am considering reducing the feed to the cam bearings, i have read that it is possible to fit drilled 1/8bsp threaded plugs into the galleries, my question is, is it a necessary to add o rings to the bushes at the same time, or is that just a further improvement? The bush has a groove Running across the bearing face so I can’t believe it would be under much pressure, especially with a reduced flow.
I don’t currently have access to a lathe so keen to avoid paying someone to do machining work for me if possible!
Cam bearing oil restriction - by tomcotez - 27-12-2020, 10:13 PM
RE: Cam bearing oil restriction - by Bob Culver - 28-12-2020, 01:57 AM
RE: Cam bearing oil restriction - by Chris KC - 28-12-2020, 12:04 PM
RE: Cam bearing oil restriction - by dickie65 - 28-12-2020, 08:59 PM
RE: Cam bearing oil restriction - by Colin Wilks - 28-12-2020, 10:09 PM
RE: Cam bearing oil restriction - by tomcotez - 28-12-2020, 10:26 PM
RE: Cam bearing oil restriction - by dickie65 - 29-12-2020, 01:31 PM
