07-12-2020, 04:58 PM
Do check the output pressure of these pumps as many are designed for modern fuel injection systems. Vintage carb float and needle valve need to be in perfect condtion with viton or similar tip to hold back more than 3psi. Spend money on a big fancy pump and then more money on a pressure regulator?
Suffolk, UK
1925 Chummy
1934 Box
1925 Chummy
1934 Box
