Door Latch Dis-Assembly?
I should perhaps add that there is a certain manque of metal (just for you Renaud!) at some key wear points which no amount of squirty lube is going to put back on! Not overly bothered about cosmetics or friction, which is at any rate OK. I was hoping to either build up or replace worn areas of the latch bolt and bullet posts (the latter need not entail stripping the latch bolt of course).
Door Latch Dis-Assembly? - by Chris KC - 05-12-2020, 04:33 PM
RE: Door Latch Dis-Assembly? - by Ian Dunford - 05-12-2020, 05:14 PM
RE: Door Latch Dis-Assembly? - by Chris KC - 05-12-2020, 05:51 PM
RE: Door Latch Dis-Assembly? - by Renaud - 05-12-2020, 05:57 PM
RE: Door Latch Dis-Assembly? - by Chris Garner - 05-12-2020, 06:02 PM
RE: Door Latch Dis-Assembly? - by Chris KC - 05-12-2020, 06:08 PM
RE: Door Latch Dis-Assembly? - by Jamie - 05-12-2020, 07:10 PM
RE: Door Latch Dis-Assembly? - by Howard Wright - 06-12-2020, 08:56 AM
RE: Door Latch Dis-Assembly? - by David.H - 06-12-2020, 10:08 AM
RE: Door Latch Dis-Assembly? - by Chris KC - 06-12-2020, 02:16 PM
RE: Door Latch Dis-Assembly? - by Renaud - 06-12-2020, 03:40 PM
RE: Door Latch Dis-Assembly? - by Chris KC - 06-12-2020, 05:52 PM
RE: Door Latch Dis-Assembly? - by Renaud - 06-12-2020, 05:56 PM
RE: Door Latch Dis-Assembly? - by Duncan Grimmond - 06-12-2020, 06:57 PM
RE: Door Latch Dis-Assembly? - by Chris KC - 06-12-2020, 11:27 PM
