  • 1 Vote(s) - 1 Average
Sump bolts
Another thing you may find handy MM, (particularly if you're trying to place a helicoil/V coil in situ above your head)  is to grab your drill press and make up a two-hole guide block with one hole drilled to minimal clearance on the o.d. of the helicoil/V coil drill and the other hole drilled for minimum clearance on the o.d. of the helicoil/V coil tap. I use scrap 50mm lengths of 30 x 10 merchant flat bar, you can either clamp the bar or hold it in your other hand depending on the job.
Invaluable if  you [like me] wear glasses, have a full beard and dislike being externally lubricated while you are trying to drill/tap squarely!
Sump bolts - by morrisminor - 02-12-2020, 08:15 PM
RE: Sump bolts - by Ruairidh Dunford - 02-12-2020, 08:19 PM
RE: Sump bolts - by morrisminor - 02-12-2020, 08:21 PM
RE: Sump bolts - by Ruairidh Dunford - 02-12-2020, 08:26 PM
RE: Sump bolts - by morrisminor - 02-12-2020, 09:00 PM
RE: Sump bolts - by Ruairidh Dunford - 02-12-2020, 09:09 PM
RE: Sump bolts - by David Stepney - 02-12-2020, 09:27 PM
RE: Sump bolts - by Howard Wright - 02-12-2020, 10:09 PM
RE: Sump bolts - by "Slack Alice" Simon - 03-12-2020, 09:44 AM
RE: Sump bolts - by John Mason - 03-12-2020, 10:35 AM
RE: Sump bolts - by "Slack Alice" Simon - 03-12-2020, 10:45 AM
RE: Sump bolts - by Chris KC - 03-12-2020, 10:59 AM
RE: Sump bolts - by Parazine - 03-12-2020, 02:35 PM
RE: Sump bolts - by morrisminor - 03-12-2020, 06:23 PM
RE: Sump bolts - by A G Wood - 04-12-2020, 12:29 AM
RE: Sump bolts - by Zetomagneto - 04-12-2020, 10:22 AM
RE: Sump bolts - by Chris KC - 04-12-2020, 10:53 AM
