Oil Pressure - Speedy
My Speedy engine with the seal and pressure valve issues attended to, and a slightly overbored oil pump runs a good 60 psi hot, I also attended to leaks around cam shaft bushes. Personally I think it would be wise to pull yours out and inspect the points raised and the bearing clearances before you do any damage.
Oil Pressure - Speedy - by Mark Dymond - 29-11-2020, 03:01 PM
RE: Oil Pressure - Speedy - by Chris.Dallas - 29-11-2020, 03:10 PM
RE: Oil Pressure - Speedy - by Chris KC - 29-11-2020, 04:06 PM
RE: Oil Pressure - Speedy - by Nick Turley - 29-11-2020, 04:32 PM
RE: Oil Pressure - Speedy - by dickie65 - 29-11-2020, 06:03 PM
RE: Oil Pressure - Speedy - by Ian Williams - 29-11-2020, 07:31 PM
RE: Oil Pressure - Speedy - by Mark Dymond - 30-11-2020, 12:42 AM
RE: Oil Pressure - Speedy - by Chris KC - 30-11-2020, 11:56 AM
RE: Oil Pressure - Speedy - by Mark Dymond - 06-01-2022, 04:55 AM
RE: Oil Pressure - Speedy - by Lowespeed - 06-01-2022, 11:57 AM
RE: Oil Pressure - Speedy - by Chris Garner - 06-01-2022, 04:15 PM
RE: Oil Pressure - Speedy - by Terrytuned - 06-01-2022, 04:33 PM
RE: Oil Pressure - Speedy - by Austin in the Shed - 08-01-2022, 11:17 AM
RE: Oil Pressure - Speedy - by Mark Dymond - 09-01-2022, 01:48 AM
RE: Oil Pressure - Speedy - by Austin in the Shed - 09-01-2022, 09:49 AM
RE: Oil Pressure - Speedy - by Mark Dymond - 01-08-2022, 02:57 PM
