Drag link end cap
If you use a flat blade screwdriver with a shaft of about 6mm.( slightly smaller than the bolt hole) you can assemble the cap on the end of the tube and stick the flat blade up the eliptical shaped hole formed by end cap and tube. At this point, twist the screwdriver through 90 degrees to form the full hole diameter and at the same time push in the bolt from the top.
Drag link end cap - by morrisminor - 25-11-2020, 06:39 PM
RE: Drag link end cap - by Reckless Rat - 25-11-2020, 07:00 PM
RE: Drag link end cap - by dickie65 - 25-11-2020, 07:07 PM
RE: Drag link end cap - by Dave Wortley - 25-11-2020, 07:55 PM
RE: Drag link end cap - by Derek Sheldon - 26-11-2020, 09:07 AM
RE: Drag link end cap - by David.H - 26-11-2020, 10:04 AM
RE: Drag link end cap - by Charles P - 26-11-2020, 10:40 AM
RE: Drag link end cap - by bob46320 - 26-11-2020, 11:29 AM
RE: Drag link end cap - by David.H - 26-11-2020, 12:46 PM
RE: Drag link end cap - by Peter Clayton - 26-11-2020, 01:06 PM
RE: Drag link end cap - by Ilmoro - 26-11-2020, 01:43 PM
RE: Drag link end cap - by Malcolm Parker - 26-11-2020, 01:50 PM
RE: Drag link end cap - by Steve Jones - 26-11-2020, 02:12 PM
RE: Drag link end cap - by Dave Wortley - 26-11-2020, 02:18 PM
RE: Drag link end cap - by Howard Wright - 26-11-2020, 02:35 PM
RE: Drag link end cap - by Reckless Rat - 26-11-2020, 02:47 PM
RE: Drag link end cap - by Renaud - 26-11-2020, 04:51 PM
RE: Drag link end cap - by Dave Wortley - 26-11-2020, 05:42 PM
RE: Drag link end cap - by dickie65 - 26-11-2020, 06:04 PM
RE: Drag link end cap - by Reckless Rat - 26-11-2020, 06:19 PM
RE: Drag link end cap - by Dave Wortley - 26-11-2020, 07:01 PM
RE: Drag link end cap - by Renaud - 26-11-2020, 08:11 PM
RE: Drag link end cap - by Malcolm Parker - 26-11-2020, 10:04 PM
RE: Drag link end cap - by Steve Jones - 26-11-2020, 10:22 PM
RE: Drag link end cap - by Malcolm Parker - 26-11-2020, 10:41 PM
RE: Drag link end cap - by Russlin - 26-11-2020, 11:45 PM
RE: Drag link end cap - by Tony Press - 27-11-2020, 01:54 AM
RE: Drag link end cap - by Bob Culver - 27-11-2020, 08:56 AM
RE: Drag link end cap - by Dave Wortley - 27-11-2020, 04:12 PM
RE: Drag link end cap - by Charles P - 27-11-2020, 04:26 PM
RE: Drag link end cap - by Dave Wortley - 27-11-2020, 06:04 PM
RE: Drag link end cap - by Mark McKibbin - 28-11-2020, 06:45 AM
RE: Drag link end cap - by AustinWood - 28-11-2020, 11:23 AM
RE: Drag link end cap - by Malcolm Parker - 28-11-2020, 01:26 PM
RE: Drag link end cap - by squeak - 28-11-2020, 09:51 PM
RE: Drag link end cap - by Howard Wright - 29-11-2020, 08:42 AM
RE: Drag link end cap - by Mick Hanna - 29-11-2020, 12:47 PM
RE: Drag link end cap - by Mark McKibbin - 30-11-2020, 10:15 AM
RE: Drag link end cap - by Bob Olive - 30-11-2020, 11:21 AM
RE: Drag link end cap - by Jeff Taylor - 30-11-2020, 03:45 PM
RE: Drag link end cap - by Duncan Grimmond - 30-11-2020, 07:11 PM
RE: Drag link end cap - by Bob Olive - 30-11-2020, 08:29 PM
RE: Drag link end cap - by Tony Press - 01-12-2020, 11:50 PM
RE: Drag link end cap - by Charles P - 02-12-2020, 12:16 AM
RE: Drag link end cap - by Tony Press - 02-12-2020, 05:27 AM
