Sump gasket
Hi Folks,
I am that Pedant !
You can feel the misfit of the threads as well.
You can swap metric and UNC in some sizes as well !!!
BSW socket cap screws are still easy to find and fine for the sump gauze and sump.
£4.25 for 20 in 5/8" Grade 12-9
I have found 1/2" x 1/4" Whit hex set bolts Grade R @ 38 pence each ( cheaper by the hundred )
I am one for paper gaskets sealed with blue hylomar and seal the sump bolts in with hylomar which does not go hard.
Sump gasket - by morrisminor - 24-11-2020, 09:27 PM
RE: Sump gasket - by Howard Wright - 24-11-2020, 09:40 PM
RE: Sump gasket - by Steve kay - 24-11-2020, 11:18 PM
RE: Sump gasket - by Terrytuned - 25-11-2020, 12:38 AM
RE: Sump gasket - by Charles P - 25-11-2020, 01:30 AM
RE: Sump gasket - by Malcolm Parker - 25-11-2020, 09:43 AM
RE: Sump gasket - by Charles P - 25-11-2020, 10:04 AM
RE: Sump gasket - by John Mason - 25-11-2020, 10:13 AM
RE: Sump gasket - by Chris KC - 25-11-2020, 10:17 AM
RE: Sump gasket - by Zetomagneto - 25-11-2020, 11:55 AM
RE: Sump gasket - by Steve Jones - 25-11-2020, 12:17 PM
RE: Sump gasket - by Chris KC - 25-11-2020, 12:24 PM
RE: Sump gasket - by Chris Garner - 25-11-2020, 12:42 PM
RE: Sump gasket - by Steve Jones - 25-11-2020, 12:59 PM
RE: Sump gasket - by Chris KC - 25-11-2020, 01:26 PM
RE: Sump gasket - by Terry McGrath - 25-11-2020, 03:17 PM
RE: Sump gasket - by mk1-mark - 25-11-2020, 04:34 PM
RE: Sump gasket - by dickie65 - 25-11-2020, 07:39 PM
RE: Sump gasket - by A G Wood - 26-11-2020, 06:38 AM
RE: Sump gasket - by Malcolm Parker - 26-11-2020, 09:58 AM
RE: Sump gasket - by John Mason - 26-11-2020, 10:06 AM
RE: Sump gasket - by David Stepney - 26-11-2020, 10:21 AM
RE: Sump gasket - by Reckless Rat - 26-11-2020, 10:27 AM
RE: Sump gasket - by Malcolm Parker - 26-11-2020, 10:37 AM
RE: Sump gasket - by David Stepney - 26-11-2020, 10:37 AM
RE: Sump gasket - by Chris KC - 26-11-2020, 12:22 PM
