17-11-2020, 12:16 PM
Thank you for the comments and suggestions. All four separate lights are now wired up and all work. One required a separate earth wire before it would flash, the other 3 are earthed back through the bumper bolts and brackets.
Brightness could be an issue. I have seen it suggested that a 21W filament bulb puts out about 250-350 lumens? Doubt these LEDs put out as much light as that. I have just been out to try the flashers for the first time in daylight. It is not sunny just at the moment, but they are visible enough.
The acid test will be whether or they still work with the engine running and the brake lights on? Not checked this yet.
