Newman Cams
Newman have provided me with a list of their standard cam profiles. It looks as if the first 3 would be suitable for road and light competition use on a light car with C/R gearbox and strong engine. Does anyone have experience of them?
I assume that 260° duration is about the limit for a road engine? It is interesting that they offer a cam with higher lift and shorter duration (A7/256/308) and one with lower lift but longer duration (A7/260/270). Any thoughts on how these would differ in performance?
Part Number     Duration @ 0.010"         Camshaft Lift     Lobe Centre Angle
A7/256/308       256°                                    0.308"                    110°
A7/260/270       260°                                    0.270"                    110°
A7/260/325       260°                                    0.325"                    110°
A7/268/310SC  268°                                     0.310"                    110°      Super Charge Camshaft
A7/284/320       284°                                    0.320"                    107.8°   Race Cam
A7/284/325       284°                                    0.320"                    107.8°   Race Cam
A7/252/314       252°                                    0.314"                    110°      Trials Cam
From what I understand a cam with 0.308" lift will fit through the centre bearing hole on a standard crank case but not one with 0.325", is that correct?  I have a ten stud block so not too worried about it lifting from the crank case, but noise and wear of the cam followers are also a factor.
Will these cams generally fit out of the box or do they need they need keys and gears to be modified to get the correct timing?
[size=7] [/size]
PS, sorry about the small font, can't seem to make it any bigger!
Newman Cams - by Tom Coates - 12-11-2020, 11:13 AM
RE: Newman Cams - by Charles P - 12-11-2020, 11:55 AM
RE: Newman Cams - by Stuart Giles - 12-11-2020, 12:22 PM
RE: Newman Cams - by Chris KC - 12-11-2020, 01:10 PM
RE: Newman Cams - by Charles P - 12-11-2020, 01:14 PM
RE: Newman Cams - by Steve Jones - 12-11-2020, 01:28 PM
RE: Newman Cams - by Tom Coates - 12-11-2020, 02:08 PM
RE: Newman Cams - by Charles P - 12-11-2020, 02:17 PM
RE: Newman Cams - by Steve Jones - 12-11-2020, 02:33 PM
RE: Newman Cams - by Tom Coates - 12-11-2020, 06:30 PM
RE: Newman Cams - by Charles P - 12-11-2020, 07:28 PM
RE: Newman Cams - by dickie65 - 12-11-2020, 09:28 PM
RE: Newman Cams - by Charles P - 12-11-2020, 11:50 PM
