  • 2 Vote(s) - 3.5 Average
Grinding a phoenix crank
(10-01-2018, 10:51 AM)Stuart Giles Wrote:
(09-01-2018, 09:26 PM)Zetomagneto Wrote:
(08-01-2018, 09:04 PM)Stuart Giles Wrote:
(08-01-2018, 02:34 PM)Zetomagneto Wrote:
(08-01-2018, 10:35 AM)Stuart Giles Wrote: Phoenix are doing me a billet crank at the moment, IIRC Marc said that the nitriding on it would be 0.020" deep
Are they doing you a special? Normally their A 7 cranks are from forging, not billet
Yes,  it is a special. Current Phoenix A7 cranks are from forgings as you say; Some earlier A7 Phoenix cranks were investment cast and then HIP treated. I have a 1 1/2" version of those here.
My understanding of a billet crank is that it is machined from a solid billet.
If I understand your reply correctly yours is from a casting , in which case it cannot be a billet crank.
A forged crank is better than a cast one, interested to know why you would be using a casting.
Just to clarify, I have an early run-of-the-mill Phoenix 1 1/2" crank here -these were investment cast, and then HIP treated. Phoenix later went over to forging for these cranks. I  am also having a one off "special" crank made by Phoenix at the moment, they're making it from EN40 billet which will then be nitrided.
Stuart that sounds very nice, can we see a picture when finished
Grinding a phoenix crank - by John L - 08-01-2018, 01:27 AM
RE: Grinding a phoenix crank - by Bob Culver - 08-01-2018, 04:14 AM
RE: Grinding a phoenix crank - by Charles P - 08-01-2018, 08:08 AM
RE: Grinding a phoenix crank - by John L - 08-01-2018, 09:52 AM
RE: Grinding a phoenix crank - by Colin Reed - 08-01-2018, 09:54 AM
RE: Grinding a phoenix crank - by Stuart Giles - 08-01-2018, 10:35 AM
RE: Grinding a phoenix crank - by Zetomagneto - 08-01-2018, 02:34 PM
RE: Grinding a phoenix crank - by leaf200 - 08-01-2018, 02:21 PM
RE: Grinding a phoenix crank - by John L - 08-01-2018, 02:25 PM
RE: Grinding a phoenix crank - by Stuart Giles - 08-01-2018, 09:04 PM
RE: Grinding a phoenix crank - by Zetomagneto - 09-01-2018, 09:26 PM
RE: Grinding a phoenix crank - by David Cochrane - 08-01-2018, 11:06 PM
RE: Grinding a phoenix crank - by Charles P - 09-01-2018, 12:15 AM
RE: Grinding a phoenix crank - by Barker - 09-01-2018, 05:45 AM
RE: Grinding a phoenix crank - by Charles P - 09-01-2018, 06:54 AM
RE: Grinding a phoenix crank - by Stuart Giles - 10-01-2018, 10:51 AM
RE: Grinding a phoenix crank - by Zetomagneto - 10-01-2018, 02:14 PM
