"New" battery can't spin starter ???
Remove the spark plugs, how does it spin over ?
Do we assume you are on 6volt system. Who reconditioned your starter and are you sure it is also 6 volt and not re-conditioned as 12 volts.
Remove the starter switch on top of the starter motor and with a jump lead from the battery, touch it onto the copper contact on the starter motor - same result ?
RE: "New" battery can't spin starter ??? - by bob46320 - 06-11-2020, 05:14 PM
