  • 1 Vote(s) - 1 Average
Grub Screws to set Clutch Toggle Lever Height
I use the roller method copy of email sent to friend on how to check lever height on a clutch I had fitted some years before after he had relined it I always measure from the steel face of the clutch to the top of the levers it is a more accurate way to set height.
(Shorts description in A7 Companion)
This helps clutch assembly.   Terry.
RE: Grub Screws to set Clutch Toggle Lever Height - by Terrytuned - 05-11-2020, 06:09 PM
