03-11-2020, 09:06 AM
(This post was last modified: 03-11-2020, 09:08 AM by Andy Bennett.)
Jamie
I had mine welded up and milled flat, but my understanding is that you set the height of the screw to the old height of the groove, so removing the wear. So you aren't actually using them to adjust the clutch, but you are using them to reset and effectively remove the differing levels of wear in the 3 toggle grooves.
Andy
Andy
