Over tightened end caps
It is generally reckoned that artisans overtighten small bolts and undertighten large ones. 5/16 is small and and 1.5 inch is very large. Spanners should be of appropriate length. The very short ring spanners are a reasonable match for mild steel and the longer for HT. 11 hp SV Hillmans, with long stroke and heavy pistons, had 5/16 16 to 20 lbs ft.
If bolts are repeatedly tightened to near or beyond yield, fatigue clocks up in a very few cycles, whereas operating at modest tension accumulate none. Best to use a separate set for fittng bearings etc.
Over tightened end caps - by 12jslater - 30-10-2020, 07:58 PM
RE: Over tightened end caps - by Nick Turley - 30-10-2020, 08:16 PM
RE: Over tightened end caps - by Steve Jones - 30-10-2020, 09:09 PM
RE: Over tightened end caps - by 12jslater - 30-10-2020, 09:14 PM
RE: Over tightened end caps - by Bob Culver - 30-10-2020, 09:16 PM
RE: Over tightened end caps - by Zetomagneto - 30-10-2020, 09:54 PM
RE: Over tightened end caps - by Chris KC - 30-10-2020, 11:01 PM
RE: Over tightened end caps - by Dave Wortley - 31-10-2020, 09:43 AM
RE: Over tightened end caps - by Zetomagneto - 31-10-2020, 09:47 AM
RE: Over tightened end caps - by John Mason - 31-10-2020, 10:13 AM
RE: Over tightened end caps - by Reckless Rat - 31-10-2020, 10:13 AM
RE: Over tightened end caps - by Charles P - 31-10-2020, 10:24 AM
RE: Over tightened end caps - by Dave Mann - 31-10-2020, 10:47 AM
RE: Over tightened end caps - by Bob Culver - 31-10-2020, 11:05 AM
RE: Over tightened end caps - by Alan - 31-10-2020, 11:14 AM
RE: Over tightened end caps - by andrew34ruby - 31-10-2020, 02:42 PM
RE: Over tightened end caps - by Colin Wilks - 31-10-2020, 03:20 PM
RE: Over tightened end caps - by Ray White - 31-10-2020, 03:43 PM
RE: Over tightened end caps - by Chris KC - 31-10-2020, 07:07 PM
RE: Over tightened end caps - by Dave Mann - 31-10-2020, 09:58 PM
RE: Over tightened end caps - by John Mason - 31-10-2020, 10:16 PM
RE: Over tightened end caps - by Zetomagneto - 31-10-2020, 10:36 PM
RE: Over tightened end caps - by Alan - 31-10-2020, 11:47 PM
RE: Over tightened end caps - by Bob Culver - 01-11-2020, 07:18 AM
RE: Over tightened end caps - by John Mason - 01-11-2020, 10:37 AM
RE: Over tightened end caps - by Ray White - 01-11-2020, 11:02 AM
RE: Over tightened end caps - by Zetomagneto - 01-11-2020, 02:02 PM
RE: Over tightened end caps - by Dave Mann - 01-11-2020, 09:10 PM
RE: Over tightened end caps - by JonE - 12-02-2021, 01:32 PM
RE: Over tightened end caps - by Robert Leigh - 12-02-2021, 01:56 PM
RE: Over tightened end caps - by jansens - 12-02-2021, 08:50 PM
RE: Over tightened end caps - by Dave Mann - 12-02-2021, 09:02 PM
RE: Over tightened end caps - by Colin Reed - 12-02-2021, 09:35 PM
RE: Over tightened end caps - by jansens - 14-02-2021, 07:55 AM
RE: Over tightened end caps - by Dave Wortley - 14-02-2021, 10:22 AM
RE: Over tightened end caps - by Dave Mann - 14-02-2021, 10:45 AM
