28-10-2020, 02:00 PM
That's great, thank you.
I take it that the front mountings are at the same height as each other?
So High frame to Low frame the angle of the engine relative to the top of the chassis rails changed.
Which accounts for the trouble one has with the nose going through the hole in the rad shell.
Which means that using a spacer under the rear mountings should bring nose back into line with the original hole.
Which I is what Mr. Rat, amongst others, said. I am just double checking I have it right.
