Piston ring replacement
Definitely don’t assume they are gapped....I did once with the obvious consequences!
And the other obvious things- take care when checking the gaps and adjusting them, they break easily, and whilst you’re about it, just make sure that when the rings are fitted to the piston and inserted into the bore they haven’t bottomed out in the groove and gone tight ...I got lucky with that one!
Piston ring replacement - by 12jslater - 24-10-2020, 02:06 PM
RE: Piston ring replacement - by Alan - 24-10-2020, 02:18 PM
RE: Piston ring replacement - by Stuart Giles - 24-10-2020, 02:47 PM
RE: Piston ring replacement - by Colin Swinbourne - 24-10-2020, 03:15 PM
RE: Piston ring replacement - by 12jslater - 24-10-2020, 05:34 PM
RE: Piston ring replacement - by Bob Culver - 24-10-2020, 06:49 PM
RE: Piston ring replacement - by David Stepney - 24-10-2020, 07:55 PM
RE: Piston ring replacement - by Zetomagneto - 24-10-2020, 08:46 PM
RE: Piston ring replacement - by 12jslater - 25-10-2020, 10:44 PM
RE: Piston ring replacement - by Zetomagneto - 25-10-2020, 10:58 PM
RE: Piston ring replacement - by 12jslater - 25-10-2020, 11:33 PM
RE: Piston ring replacement - by Zetomagneto - 26-10-2020, 03:15 PM
RE: Piston ring replacement - by Colin Wilks - 26-10-2020, 05:52 PM
RE: Piston ring replacement - by Zetomagneto - 26-10-2020, 08:18 PM
RE: Piston ring replacement - by Colin Wilks - 26-10-2020, 09:01 PM
