Piston ring replacement
If they're Hepolite replacement rings, the top ring is usually a "Ridge Dodger" style ring with a step on the outside of the ring so that the new ring never actually reaches the ridge.
If I didn't have a ridge reamer, I'd be inclined to use a sharp bearing scraper to blend out the the ridge once the glaze has been removed.
I always check ring gaps when I rebuild an engine, only takes a few minutes, stick the piston 'upside down' down the bore to ensure the ring isn't crooked which would exaggerate the gap.
Piston ring replacement - by 12jslater - 24-10-2020, 02:06 PM
RE: Piston ring replacement - by Alan - 24-10-2020, 02:18 PM
RE: Piston ring replacement - by Stuart Giles - 24-10-2020, 02:47 PM
RE: Piston ring replacement - by Colin Swinbourne - 24-10-2020, 03:15 PM
RE: Piston ring replacement - by 12jslater - 24-10-2020, 05:34 PM
RE: Piston ring replacement - by Bob Culver - 24-10-2020, 06:49 PM
RE: Piston ring replacement - by David Stepney - 24-10-2020, 07:55 PM
RE: Piston ring replacement - by Zetomagneto - 24-10-2020, 08:46 PM
RE: Piston ring replacement - by 12jslater - 25-10-2020, 10:44 PM
RE: Piston ring replacement - by Zetomagneto - 25-10-2020, 10:58 PM
RE: Piston ring replacement - by 12jslater - 25-10-2020, 11:33 PM
RE: Piston ring replacement - by Zetomagneto - 26-10-2020, 03:15 PM
RE: Piston ring replacement - by Colin Wilks - 26-10-2020, 05:52 PM
RE: Piston ring replacement - by Zetomagneto - 26-10-2020, 08:18 PM
RE: Piston ring replacement - by Colin Wilks - 26-10-2020, 09:01 PM
