Rear main bearing - fitting
(19-10-2020, 01:44 PM)Parazine Wrote: Can't see that it makes much difference. I usually fit the inner first, having previously fitted and removed the outer to check there won't be any problems.....
And I normally do it the other way round but I agree, can't see it makes much difference either way.
Rear main bearing - fitting - by Mick Hanna - 19-10-2020, 12:57 PM
RE: Rear main bearing - fitting - by Parazine - 19-10-2020, 01:44 PM
RE: Rear main bearing - fitting - by Steve Jones - 19-10-2020, 01:59 PM
RE: Rear main bearing - fitting - by Chris KC - 19-10-2020, 02:55 PM
RE: Rear main bearing - fitting - by Mick Hanna - 19-10-2020, 03:08 PM
RE: Rear main bearing - fitting - by Chris KC - 19-10-2020, 03:52 PM
RE: Rear main bearing - fitting - by David Witton - 19-10-2020, 06:04 PM
RE: Rear main bearing - fitting - by Bob Culver - 19-10-2020, 08:08 PM
RE: Rear main bearing - fitting - by Ian Williams - 19-10-2020, 08:17 PM
RE: Rear main bearing - fitting - by Tony Press - 19-10-2020, 11:26 PM
RE: Rear main bearing - fitting - by Mick Hanna - 20-10-2020, 10:30 AM
RE: Rear main bearing - fitting - by Mick Hanna - 23-10-2020, 04:12 PM
RE: Rear main bearing - fitting - by Tony Press - 23-10-2020, 10:22 PM
RE: Rear main bearing - fitting - by Mick Hanna - 24-10-2020, 10:38 AM
