Hub lip seal (modern replacement)
I have only fitted the ones from 7Workshop but I suspect they are identical.
Remove old felt seal, place lip seal in position (open end towards the outside of the car), place spacer washer next and then bearing. Use the bearing to press the new lip seal into place, it is an interference fit into the inner wheel carrier. I use a hydraulic press but a vice will work, if used carefully.
Lubricate the lip with suitable grease and fit to axle.
Hub lip seal (modern replacement) - by John Mason - 17-10-2020, 02:15 PM
RE: Hub lip seal (modern replacement) - by Ruairidh Dunford - 17-10-2020, 02:27 PM
RE: Hub lip seal (modern replacement) - by RossV - 31-01-2022, 03:36 AM
