Power TO the dynamo!
(15-10-2020, 02:48 PM)David.H Wrote: Thank you Howard,
Yes everything DID work, so I am likely to have upset something! My real question is whether with the ignition ON should a voltage go to "energise" the dynamo? (D+ to D) I am not getting any voltage to the dynamo D  nor the cut out D, so I think the most likely culprit is that the switch panel is playing up and that maybe I have disturbed the wire between D+ and IGN on the switch panel.
John Cornforth wrote to me at length about a similar problem on another car (turned out to be a faulty cut out coil!)
Cars like to do this just after you try to sell them.....!
I think I will dismantle the switch panel (I can almost do it blindfold now!)
The Cornwall article is excellent.
Thanks
D
"My real question is whether with the ignition ON should a voltage go to "energise" the dynamo?"
answer is...  NO.   Unless I'm wrong.
Power TO the dynamo! - by David.H - 14-10-2020, 04:52 PM
RE: Power TO the dynamo! - by Bob Culver - 14-10-2020, 07:49 PM
RE: Power TO the dynamo! - by Howard Wright - 15-10-2020, 10:22 AM
RE: Power TO the dynamo! - by David.H - 15-10-2020, 02:48 PM
RE: Power TO the dynamo! - by andrew34ruby - 15-10-2020, 07:19 PM
RE: Power TO the dynamo! - by Stuart Giles - 15-10-2020, 07:22 PM
RE: Power TO the dynamo! - by David.H - 15-10-2020, 09:53 PM
RE: Power TO the dynamo! - by Bob Culver - 16-10-2020, 01:03 AM
RE: Power TO the dynamo! - by JonE - 16-10-2020, 12:13 PM
RE: Power TO the dynamo! - by Stuart Giles - 17-10-2020, 08:48 AM
RE: Power TO the dynamo! - by JonE - 17-10-2020, 09:18 AM
RE: Power TO the dynamo! - by Stuart Giles - 17-10-2020, 11:13 AM
RE: Power TO the dynamo! - by JonE - 17-10-2020, 08:57 PM
RE: Power TO the dynamo! - by Stuart Giles - 17-10-2020, 09:42 PM
RE: Power TO the dynamo! - by Ian McGowan - 18-10-2020, 01:23 AM
RE: Power TO the dynamo! - by JonE - 18-10-2020, 08:45 AM
RE: Power TO the dynamo! - by David.H - 20-10-2020, 09:17 PM
RE: Power TO the dynamo! - by Bob Culver - 21-10-2020, 12:38 AM
RE: Power TO the dynamo! - by JonE - 21-10-2020, 01:44 PM
