Ignition fault finding
The distributor is a DK4A so no issues with hidden resistors, but yes, I have replaced the rotor arm anyway.
I have now replaced the condenser with a new, tested one. No difference. Also replaced the distributor base plate with one that was in use a couple of months ago. No difference.
Andrew, I disconnected the coil and put a voltmeter (rather than a bulb) across the low tension wires. As I crank the engine it flicks between 12v and 6v - not what I expected. Does this suggest there is some leakage across the points? I'm beginning to think there is a short in the loom somewhere given that all the other components have been replaced.
Peter.
Ignition fault finding - by Peter Naulls - 06-01-2018, 06:52 PM
RE: Ignition fault finding - by Colin Wilks - 06-01-2018, 07:07 PM
RE: Ignition fault finding - by Peter Naulls - 06-01-2018, 07:16 PM
RE: Ignition fault finding - by Colin Wilks - 06-01-2018, 07:35 PM
RE: Ignition fault finding - by Charles Levien - 06-01-2018, 07:55 PM
RE: Ignition fault finding - by DavidB - 06-01-2018, 08:00 PM
RE: Ignition fault finding - by andrew34ruby - 06-01-2018, 09:40 PM
RE: Ignition fault finding - by Peter Naulls - 06-01-2018, 09:48 PM
RE: Ignition fault finding - by Duncan Grimmond - 06-01-2018, 09:59 PM
RE: Ignition fault finding - by Nick Mayne - 07-01-2018, 01:04 AM
RE: Ignition fault finding - by DavidB - 07-01-2018, 03:20 AM
RE: Ignition fault finding - by Dave Mann - 07-01-2018, 12:50 PM
RE: Ignition fault finding - by John Mason - 07-01-2018, 01:40 PM
RE: Ignition fault finding - by Peter Naulls - 07-01-2018, 04:12 PM
RE: Ignition fault finding - by John Cornforth - 07-01-2018, 07:02 PM
RE: Ignition fault finding - by andrew34ruby - 09-01-2018, 01:28 PM
RE: Ignition fault finding - by Duncan Grimmond - 07-01-2018, 06:55 PM
RE: Ignition fault finding - by Peter Naulls - 07-01-2018, 07:29 PM
RE: Ignition fault finding - by Duncan Grimmond - 07-01-2018, 08:08 PM
RE: Ignition fault finding - by daveg - 07-01-2018, 08:49 PM
RE: Ignition fault finding - by John Mason - 08-01-2018, 05:23 PM
RE: Ignition fault finding - by Peter Naulls - 08-01-2018, 10:31 PM
RE: Ignition fault finding - by Ruairidh Dunford - 08-01-2018, 10:47 PM
RE: Ignition fault finding - by John Mason - 09-01-2018, 09:58 AM
