Phoenix crank
I've just received a partially dismantled engine which suffered two pistons which lost bits of their skirts, together with a rebuilt block and my task is to put it together. The phoenix crank was still in the crankcase so it got a good cleaning which revealed the rear main was spinning on the shaft so that came out which revealed the rollers were damaged. Then I spied that there has been light contact between the center of the crank and the camshaft center bearing housing. Is there a clearance issue with 15/16" two bearing jet fed phoenix cranks?
Phoenix crank - by Dave Mann - 11-10-2020, 08:52 PM
RE: Phoenix crank - by Ruairidh Dunford - 11-10-2020, 09:03 PM
RE: Phoenix crank - by Steve Jones - 11-10-2020, 09:05 PM
RE: Phoenix crank - by Bob Culver - 11-10-2020, 10:27 PM
RE: Phoenix crank - by Dave Mann - 11-10-2020, 10:29 PM
RE: Phoenix crank - by Zetomagneto - 11-10-2020, 10:42 PM
RE: Phoenix crank - by Ruairidh Dunford - 11-10-2020, 11:13 PM
RE: Phoenix crank - by Dave Mann - 13-10-2020, 08:37 AM
RE: Phoenix crank - by Ruairidh Dunford - 13-10-2020, 09:01 AM
RE: Phoenix crank - by Tony Griffiths - 13-10-2020, 09:11 AM
RE: Phoenix crank - by Bob Culver - 13-10-2020, 09:20 AM
RE: Phoenix crank - by Dave Mann - 13-10-2020, 08:16 PM
RE: Phoenix crank - by Bob Culver - 13-10-2020, 10:03 PM
RE: Phoenix crank - by AllAlloyCup - 13-10-2020, 10:46 PM
RE: Phoenix crank - by Ruairidh Dunford - 13-10-2020, 10:54 PM
RE: Phoenix crank - by Dave Mann - 15-10-2020, 09:04 PM
RE: Phoenix crank - by Bob Culver - 16-10-2020, 06:29 AM
RE: Phoenix crank - by Dave Mann - 16-10-2020, 08:23 PM
