Regulations regarding specials
Washers and wipers not required if windsreen opens or folds ( ie view to front without looking through the glass). Nor are lights, ( for daytime use) but if fitted you must have:
Two front position lamps /sidelights ( can be in the headlamps) a matched pair of headlamps ( do not need to dip if they are permanently deflected downwards so as not to dazzle)
Two rear position lamps, two brake lamps, rear number plate lamp. Indicators not required but if fitted must work and have either audible beeper or warning lamp bisible to the driver, plus two red rear reflectors ( which may form part of rear position lamp. Rear lights must be at least 2 sq in in area.
For details see road vehicles lighting regulations.( hours of darkness)
Daytime use is governed by the road vehicles constructin and use regulations.
RE: Regulations regarding specials - by GK5268 - 10-10-2020, 11:35 AM
RE: Regulations regarding specials - by Rick F - 10-10-2020, 11:44 AM
RE: Regulations regarding specials - by Reckless Rat - 11-10-2020, 08:08 PM
RE: Regulations regarding specials - by Dirk73 - 12-10-2020, 09:20 PM
