water temperature
Hi
A few years back I fitted a temporary gauge (thermocouple) to my late '38 Ruby and found it was running at about 90 degrees C on an average day.  Trying the gauge again on a hot summer's day, it was only a couple degrees warmer.  Also, the late Ruby system is slightly pressurised - there is a relief valve fitted before the overflow - so 100 degrees is not the boiling temperature even with fresh water - it will be higher - and the 30% anti-freeze will also raise it.  In practice, my car has never boiled when there has been enough water to allow circulation.
So I have stopped worrying about it, other than checking the water level.  (One thing that might help counteract the age of the radiator core is that it is the straight-through channel type, rather than the original zigzag - this later one being more efficient?)
Colin
water temperature - by Thowdfella - 05-01-2018, 04:36 PM
RE: water temperature - by Reckless Rat - 05-01-2018, 05:19 PM
RE: water temperature - by Phil Kingdom - 05-01-2018, 06:12 PM
RE: water temperature - by Chris KC - 06-01-2018, 08:40 AM
RE: water temperature - by Ruairidh Dunford - 06-01-2018, 11:23 AM
RE: water temperature - by Steve Jones - 06-01-2018, 11:38 AM
RE: water temperature - by Reckless Rat - 06-01-2018, 12:14 PM
RE: water temperature - by Colin Morgan - 06-01-2018, 02:13 PM
RE: water temperature - by Steve kay - 11-01-2018, 05:33 PM
RE: water temperature - by Chris KC - 12-01-2018, 08:44 AM
