  • 1 Vote(s) - 4 Average
Dynamators Gear Wear & Reliability
#61
had the same problem, more noticeable on the cam gear then the dizzy gear, (due to the iron cam gear wearing rapidly in relation to the new steel gear on the dynamator) cam gear totally buggered and copious debris in the sump.
Clearly Accuspark tech department have not been able to replicate the exact geometry of the original A7 gears.
If they made a new steel cam gear to fit the geometry of their dynamo gear - that might be a solution
although i suspect it then wouldn't mesh correctly with the crank gear...
Dynamators Gear Wear & Reliability - by mk1-mark - 15-01-2019, 04:45 PM
RE: Dynamators Gear Wear & Reliability - by Alan - 03-03-2019, 11:44 AM
RE: Dynamators Gear Wear & Reliability - by Alan - 08-03-2019, 09:22 PM
RE: Dynamators Gear Wear & Reliability - by Dirk73 - 06-10-2020, 07:50 PM
