Carden joint - prop shaft lubrication
Do you have a body number stamped on the tunnel which would be just behind the gearbox (Under your wooden Box) If you don't, then the tunnel is a replacement.
RE: Carden joint - prop shaft lubrication - by bob46320 - 02-10-2020, 12:38 PM
