Ringing Cranks
Whilst hewing path through my basement I stumbled upon my collection of cracked cranks. There has occasionally been mention of ringing so I had a little play. I have rung many Javelin cranks and timed the sound and found wide variation between shafts apparently  all OK and one with small crack. I have hung Seven shafts from the front and rear with no conclusions. This time I rested on a narrow edge at the centre. With the other end held the fronts rang clearly better than the rear where the known cracks are. Has anyone done this with a known good crank and is there a significant difference depending whether the front or rear rung?
Ringing Cranks - by Bob Culver - 21-09-2020, 07:56 AM
RE: Ringing Cranks - by Chris KC - 21-09-2020, 09:37 AM
RE: Ringing Cranks - by Alan - 21-09-2020, 10:10 AM
RE: Ringing Cranks - by Chris KC - 21-09-2020, 10:21 AM
RE: Ringing Cranks - by Bob Culver - 21-09-2020, 10:39 AM
RE: Ringing Cranks - by David Stepney - 21-09-2020, 03:32 PM
RE: Ringing Cranks - by mk1-mark - 21-09-2020, 04:37 PM
RE: Ringing Cranks - by Ivor Hawkins - 22-09-2020, 10:56 AM
