Oil Pressure Relief Valve - Three Bearing Engine
Jamie some engines have been modified to redirect the oil flow by insertion of strategically located plugs in the oil galleries. Commonly for pressure feed and/or oil filter addition. It's important you understand exactly what's going on with your system before making changes. A long piece of wire and a poke around is a good start.
RE: Oil Pressure Relief Valve - Three Bearing Engine - by squeak - 21-09-2020, 01:47 AM
