Front main bearing removal
Hi All
On my last build I managed to get permission to use the domestic oven.   Lined it with foil and stuck most of the crank in so that the door remain ajar. Although set at 100 degrees having the door open reduced the temperature a bit. I have a length of 8mm stainless rod to use as a drift but after heating it almost fell out.
Good luck
Front main bearing removal - by jamesheath - 17-09-2020, 01:42 PM
RE: Front main bearing removal - by Chris KC - 17-09-2020, 04:27 PM
RE: Front main bearing removal - by John Mason - 17-09-2020, 04:53 PM
RE: Front main bearing removal - by Howard Wright - 17-09-2020, 05:06 PM
RE: Front main bearing removal - by Steve Jones - 17-09-2020, 06:34 PM
RE: Front main bearing removal - by Chris KC - 17-09-2020, 07:38 PM
RE: Front main bearing removal - by Bob Culver - 17-09-2020, 07:45 PM
RE: Front main bearing removal - by Jamie - 17-09-2020, 10:15 PM
RE: Front main bearing removal - by jamesheath - 18-09-2020, 05:15 PM
