Replace the dog
Tony Griffiths Wrote:Is it possible to use the later type on a mag engine? Obviously the handle would need modifying....
No, the Mag dog is quite different, long enough to stick out of the timing case altogether. It has a pulley mounted on it as well, so there's a parallel part reaching back inside the engine.
Nick Salmon Wrote:Not having done this particular job before on an early engine, when removing the timing gear cover is there anything likely to fall/spring out (timing gear bearings?) and thus cause me to have to take the engine out and entirely dismantle it in order to get the tiny widget back in?!
Removal of the cover is not trivial as it supports the timing gear bearings. AMoCo provided some "ears" on the casting to allow you to tap it off but many of these are broken, a testament to inexperience! There is nothing to "jump out" per se, just difficulty in tapping the cover off the bearings. See pic below.
Replace the dog - by Nick Salmon - 15-09-2020, 07:31 AM
RE: Replace the dog - by Ian Williams - 15-09-2020, 07:39 AM
RE: Replace the dog - by Parazine - 15-09-2020, 07:53 AM
RE: Replace the dog - by Nick Salmon - 15-09-2020, 02:20 PM
RE: Replace the dog - by AustinWood - 15-09-2020, 03:07 PM
RE: Replace the dog - by austin - 15-09-2020, 03:20 PM
RE: Replace the dog - by Tony Betts - 15-09-2020, 03:28 PM
RE: Replace the dog - by Tony Griffiths - 15-09-2020, 03:57 PM
RE: Replace the dog - by Nick Salmon - 15-09-2020, 05:15 PM
RE: Replace the dog - by Howard Wright - 15-09-2020, 06:36 PM
RE: Replace the dog - by David Cochrane - 15-09-2020, 09:18 PM
RE: Replace the dog - by Tony Griffiths - 15-09-2020, 10:08 PM
RE: Replace the dog - by David Cochrane - 15-09-2020, 10:15 PM
RE: Replace the dog - by Parazine - 16-09-2020, 07:48 AM
RE: Replace the dog - by Nick Salmon - 16-09-2020, 08:04 AM
RE: Replace the dog - by David Witton - 16-09-2020, 10:14 AM
RE: Replace the dog - by Roy Player - 16-09-2020, 10:18 AM
RE: Replace the dog - by Parazine - 16-09-2020, 10:21 AM
RE: Replace the dog - by Robert Leigh - 16-09-2020, 11:03 AM
RE: Replace the dog - by Nick Salmon - 16-09-2020, 05:58 PM
