11-09-2020, 11:27 AM
(10-09-2020, 01:32 PM)Nick Turley Wrote: My gearbox gets EP90 and runs well after 87k miles of use.As Nick correctly states, if an EP oil has an API rating of either GL-4 or GL-5 then the sulphur is inactive and safe to use in boxes with bronze bearings. Oddly, for use in many types of machine tool - including the geared headstocks and screwcutting gearboxes of lathes and milling machines - manufacturers from the 1940s onwards recommended a thin "anti-wear" Hydraulic oil such as Shell Tellus.
Millers chemist recommended such use to me 30 years ago
It is incorrect, as I am sure most know to think that EP oils dissolve brass and bronze, this has been the case since the advent of GL4 and Gl5 spec oils (a long time).
The wear factor of such oils in gearboxes and back axles is much reduced.
