08-09-2020, 07:27 AM
Hi Jamie
That radius arm look a bit dangerous to me! As Greig says Tony Betts should be able to help out with an arm. Although I may just have had the last two . Once cleaned up grind off the rivets and separate the end. I had a local blacksmith redo the hot rivets on two arms recently (£20). Rivets are better than bolts here as the radius arm end has sloping sides and you would need wedge shaped washers if using bolts.
