Query about gearing...
Hi Duncan
You are right to be disappointed.
With the set up you have and a light body as you have.
I would expect a good 65 MPH.
With your four speed gearbox which is direct in fourth and a girling axle (5.25) it should be super.
I am of course guessing but I would suspect the carburettor may be the problem.
It may be worth sticking a standard carb on temporally just to compare if you have one, if you haven't I can lend you one.
Then you can plan your next move.
My RP which is heavy of course will do 55 MPH and he is all standard apart from the rear axle which is the same as yours.
Query about gearing... - by Duncan Grimmond - 05-09-2020, 09:30 AM
RE: Query about gearing... - by Nick Turley - 05-09-2020, 09:57 AM
RE: Query about gearing... - by Duncan Grimmond - 05-09-2020, 10:06 AM
RE: Query about gearing... - by dickie65 - 05-09-2020, 10:14 AM
RE: Query about gearing... - by Malcolm Parker - 05-09-2020, 10:40 AM
RE: Query about gearing... - by Chris KC - 05-09-2020, 10:42 AM
RE: Query about gearing... - by JonE - 05-09-2020, 11:30 AM
RE: Query about gearing... - by Steve kay - 05-09-2020, 09:24 PM
RE: Query about gearing... - by Bob Culver - 05-09-2020, 11:33 PM
RE: Query about gearing... - by andrew34ruby - 05-09-2020, 11:36 PM
RE: Query about gearing... - by Tony Betts - 06-09-2020, 02:16 AM
RE: Query about gearing... - by Chris Garner - 06-09-2020, 07:55 AM
RE: Query about gearing... - by Dave Mann - 06-09-2020, 08:50 AM
RE: Query about gearing... - by Mike Costigan - 06-09-2020, 09:03 AM
RE: Query about gearing... - by Alan - 06-09-2020, 10:38 AM
RE: Query about gearing... - by Stuart Giles - 06-09-2020, 10:41 AM
RE: Query about gearing... - by Duncan Grimmond - 06-09-2020, 10:59 AM
RE: Query about gearing... - by Steve Jones - 06-09-2020, 11:33 AM
RE: Query about gearing... - by Duncan Grimmond - 06-09-2020, 01:51 PM
RE: Query about gearing... - by Howard Wright - 06-09-2020, 02:04 PM
RE: Query about gearing... - by Stuart Giles - 06-09-2020, 02:21 PM
RE: Query about gearing... - by Charles P - 06-09-2020, 05:57 PM
RE: Query about gearing... - by Steve Jones - 06-09-2020, 06:51 PM
RE: Query about gearing... - by Charles P - 06-09-2020, 07:25 PM
RE: Query about gearing... - by Duncan Grimmond - 06-09-2020, 07:50 PM
RE: Query about gearing... - by Duncan Grimmond - 07-09-2020, 08:40 AM
RE: Query about gearing... - by Bob Culver - 07-09-2020, 09:02 AM
RE: Query about gearing... - by Duncan Grimmond - 07-09-2020, 12:52 PM
RE: Query about gearing... - by Reckless Rat - 07-09-2020, 01:16 PM
RE: Query about gearing... - by Stuart Giles - 07-09-2020, 01:18 PM
RE: Query about gearing... - by Renaud - 07-09-2020, 01:22 PM
RE: Query about gearing... - by Alan - 07-09-2020, 01:41 PM
RE: Query about gearing... - by Duncan Grimmond - 07-09-2020, 02:06 PM
RE: Query about gearing... - by Reckless Rat - 07-09-2020, 02:44 PM
RE: Query about gearing... - by Duncan Grimmond - 07-09-2020, 04:08 PM
RE: Query about gearing... - by andrew34ruby - 07-09-2020, 04:19 PM
RE: Query about gearing... - by Reckless Rat - 07-09-2020, 04:23 PM
RE: Query about gearing... - by andrew34ruby - 07-09-2020, 04:41 PM
RE: Query about gearing... - by Duncan Grimmond - 07-09-2020, 05:28 PM
RE: Query about gearing... - by andrew34ruby - 07-09-2020, 05:54 PM
RE: Query about gearing... - by Duncan Grimmond - 07-09-2020, 05:56 PM
RE: Query about gearing... - by Malcolm Parker - 07-09-2020, 09:46 PM
RE: Query about gearing... - by andrew34ruby - 08-09-2020, 08:40 AM
RE: Query about gearing... - by Malcolm Parker - 08-09-2020, 10:52 AM
RE: Query about gearing... - by Bob Culver - 08-09-2020, 11:27 AM
RE: Query about gearing... - by andrew34ruby - 09-09-2020, 01:55 PM
RE: Query about gearing... - by Malcolm Parker - 09-09-2020, 02:27 PM
RE: Query about gearing... - by Bob Culver - 09-09-2020, 09:15 PM
RE: Query about gearing... - by andrew34ruby - 09-09-2020, 09:31 PM
RE: Query about gearing... - by Ian Williams - 10-09-2020, 08:59 PM
RE: Query about gearing... - by Spex - 10-09-2020, 09:08 PM
RE: Query about gearing... - by Chris KC - 10-09-2020, 10:36 PM
RE: Query about gearing... - by Malcolm Parker - 11-09-2020, 08:26 AM
RE: Query about gearing... - by andrew34ruby - 11-09-2020, 09:27 AM
RE: Query about gearing... - by Bob Culver - 11-09-2020, 09:35 AM
RE: Query about gearing... - by Colin Reed - 11-09-2020, 10:20 AM
RE: Query about gearing... - by Renaud - 11-09-2020, 11:00 AM
RE: Query about gearing... - by Chris KC - 11-09-2020, 12:07 PM
RE: Query about gearing... - by Howard Wright - 11-09-2020, 01:00 PM
RE: Query about gearing... - by Howard Wright - 11-09-2020, 07:48 PM
RE: Query about gearing... - by Ian Williams - 11-09-2020, 10:08 PM
RE: Query about gearing... - by Alan - 11-09-2020, 10:17 PM
RE: Query about gearing... - by Colin Reed - 12-09-2020, 10:05 AM
RE: Query about gearing... - by Bob Culver - 12-09-2020, 11:23 AM
RE: Query about gearing... - by Tod - 12-09-2020, 02:26 PM
RE: Query about gearing... - by Bob Culver - 13-09-2020, 02:53 AM
RE: Query about gearing... - by Alan - 13-09-2020, 10:13 AM
RE: Query about gearing... - by Mike Costigan - 13-09-2020, 10:52 AM
RE: Query about gearing... - by Ivangardiner - 13-09-2020, 11:31 AM
RE: Query about gearing... - by Duncan Grimmond - 13-09-2020, 12:21 PM
RE: Query about gearing... - by Steve Jones - 13-09-2020, 01:43 PM
RE: Query about gearing... - by Nick Lettington - 14-09-2020, 08:43 AM
RE: Query about gearing... - by Howard Wright - 14-09-2020, 02:11 PM
RE: Query about gearing... - by andrew34ruby - 17-09-2020, 06:32 PM
RE: Query about gearing... - by Ian Williams - 18-09-2020, 03:56 AM
RE: Query about gearing... - by andrew34ruby - 18-09-2020, 09:34 AM
RE: Query about gearing... - by Howard Wright - 18-09-2020, 10:08 AM
RE: Query about gearing... - by Nick Turley - 18-09-2020, 10:10 AM
RE: Query about gearing... - by Parazine - 18-09-2020, 10:23 AM
RE: Query about gearing... - by Renaud - 18-09-2020, 10:55 AM
RE: Query about gearing... - by Bob Culver - 18-09-2020, 11:08 AM
RE: Query about gearing... - by Malcolm Parker - 18-09-2020, 11:22 AM
RE: Query about gearing... - by Tony Press - 18-09-2020, 11:18 PM
RE: Query about gearing... - by Duncan Grimmond - 19-09-2020, 10:21 AM
RE: Query about gearing... - by Malcolm Parker - 19-09-2020, 12:18 PM
RE: Query about gearing... - by Dave Wortley - 19-09-2020, 12:56 PM
RE: Query about gearing... - by Steve Jones - 19-09-2020, 02:50 PM
RE: Query about gearing... - by Duncan Grimmond - 20-09-2020, 03:40 PM
RE: Query about gearing... - by Duncan Grimmond - 22-09-2020, 08:07 AM
RE: Query about gearing... - by Malcolm Parker - 22-09-2020, 08:43 AM
RE: Query about gearing... - by Renaud - 22-09-2020, 08:44 AM
RE: Query about gearing... - by JonE - 22-09-2020, 08:47 AM
RE: Query about gearing... - by andrew34ruby - 22-09-2020, 09:43 AM
RE: Query about gearing... - by Steve Jones - 22-09-2020, 11:13 AM
RE: Query about gearing... - by Nick Turley - 22-09-2020, 12:31 PM
