Speedo calibration and/or axle ratio change
Colin,
Won't fix the OP's problem as his speedo was originally driven from the propshaft and has 3360 TPM gearing. He'll end up with 2/3 speed reading......
He could follow your advice but would then need to build a special "A" type, like I did with PN type governor or use a PA or other 2240 TPMĀ speedo.
RE: Speedo calibration and/or axle ratio change - by Parazine - 03-09-2020, 10:10 AM
